As I am eagerly awaiting my Dwarf to turn up, I can’t help but wonder what to do with the control chain option.
Having it described as better than MIDI, i couldnt wait to see what additional hardware is available but only found 4 button footwitch : (
Then I found the arduino shield which looked promising to find a sketch for one button or one potentiometer : (
I did stumble across a 4 knob 2 screen box but cant find it anymore.
So heres my thoughts.
Is it really better than midi ? If so why only basic controllers?
I use a sketch made by Dave at Notes and Volts to make really cool controllers with 16 pots and 16 switches with ease. And I have no idea how to program arduinos but its so easy to change to what I need.
Can we work together to build a similar type of generic sketch that can be altered to suit?
Also how about having a blank dwarf case with the ethernet cut outs and powder coating to match to be drilled and machined to taste ?
Really hoping this can turn into something special and look forward to everyones responses
P.s moved from uncategorized - hope thats ok
