Hello, my intention is to model a couple of presets from the Lossy plugin by Ghz, or the pedal.
I’m really a beginner, but I tried this troubleshooting. I’m not sure if it’s correct or not, but I wanted to make an initial attempt. I have a few questions:
I’m using AIDA-X Trainer Model and I tried to download its input file. I created the target file by bouncing the same file with the effect applied. I only used one preset, followed all the necessary steps, but I’m getting this error at the Model training step:
KeyError: 'test_lossESR_final'
I wanted to know first of all if it is possible to model any pedal in this way (but I believe it is), and I would like to understand why I’m unable to proceed.
Last thing, i see your file is guitar audio, i mainly use MDX for synths and drum machines, i need to use a different input file?
Thank you in advance for any help.
