Change of snapshots - How to get "Tail" for Delay and Reverb
Is there a possibility to get a smoother change of snapshots using “Tail” on Delay or/and Reverb like other rmodellers provide?
I am using two AiDA-X amps with the same small chain and want to switch between the Clean and Gain amp and when I switch from Gain back to Clean I get a “click” sound. The switch latency is o.k. but I would like to get it smoother for live perfomance.
Any ideas?
Thomas
Yes, you can use this kind of switch box Switchbox 1-2 ST - MOD Audio to send (or not send) your clean sound into reverbs ir delays.
Personally y prefer using this simple Volume 2x2 - MOD Audio because I can chose the amount of signal I send to the full wet reverb or delay.
Your reverbs and delays should the go straight to your outputs.
This is how reverbs are usually used in a console or in a DAW, you can send the amount you want of each line in a single reverb (instead of bying 32 reverbs, or using and adjusting 32 plugins)…
Thanks. I have used the amps in parellel mode now, that works much better.
