Is there a ay to change channels e.g. from the purchased Marshall JCVM via MIDI?
In the channel settings there is only possible to assign to the device itself or to the control chain.
I would like that too. As a workaround you could possibly do it via snapshots, I think.
yes, that is what I do now.
I wonder if there is a way without snapshots.
An approach that I’ve seen listed here on the Forum for a few things is to use midi to alter a CV plugin which in turn can alter other plugins, this might work here.
ok, I will try. Thank you
