Cc control / midi - pedalboard / snapshot change
Hi
I’ve figured out how to control snapshot / pedalboards using assign all - this allows me to scroll through based on the creation order using footswitch.
Is it at all possible to assign a specific pedalboard or snapshot to a switch ? I can use control change or midi
I think dwarf would be more gig friendly with :
Hierarchy of changes along the lines of set list → song → song part
With smart coding you can use hierarchy to check for values at the lowest level. I suppose that would need major change.
It should be okay for me I’m playing using 4 tones only mostly.
Ta
Nelly
You can use MIDI PC codes to switch pedalboards or snapshots :
https://wiki.mod.audio/wiki/Device_Settings#Sync_.26_MIDI
With the infamous mindi plugin and virtual MIDI loopback, you should be able to assign a specific pedalbord or snapshot to a footswitch.
https://wiki.mod.audio/wiki/MOD_Web_GUI_User_Guide#MIDI_USB
