Hi all
Sorry, this is probably a very noobish question, I’m not so tech-savvy regarding electronics.
While reading the capturing guide I stumbled over the need for a reamp box to match impedance between the sound interface out and the amp in.
I was wondering, if reamping is still necessary if I play the input.wav provided by MOD from the Dwarf using the audio player plugin. Or, alternatively, if I play the guitar myself into the Dwarf while
- Dwarf out 1 goes to audio interface to record a “dry” track for input.wav
- Dwarf out 2 goes to amp [etc.] to record a “wet” track for output.wav
Is that rubbish?
You will probably capture the sound of your amp with a microphone?
Than your speaker is ‘taking the load’ and you are all set.
The reamping guide speaks of a loadbox for scenario’s where you don’t want to mic up and you want the sound that comes right out of the pre-amp section of your amplifier.
The upside for you is: you’re all set
the downside is: the placement and character of your microphone becomes part of the sound.
Thanks for the reply. Maybe I’m getting you wrong, but I’m not talking about the DI box that takes the signal from the pre-amp out for cases of direct recording. I rather meant the signal path to the pre-amp - independent of whether you capture directly or by micing the cab.
Excuse my crappy drawing skills, but I thought this might explain it better.
Would either of these two variations yield comparable results to what is describe in the guide?
