I am a bass player and I am trying to use of the “Capo” plugin with my Mod Duo.
The problem is that any notes below “D” progressively have some kind of “wobble” in the sound that gets worse the lower you get in the notes.
This wobble sounds like if the original note is played microseconds apart of the modified note.
Is this because the current Capo plugin is designed for guitars and a new version of the plugin should be adapted to bass or is it that low frequencies are simply more difficult to deal with?
