I can’t manually update my MOD DUO. It is on verison 0.12 I believe, as it is not automatically updating when accessing the web interface.
When following the described steps everything works until I unplug the USB. Then it says ‘eject not detect’.
I’ve tried ejecting via the finder context menut, moving to trash, disk utility in the terminal and gui and even tho it says “not mounted” the MOD itself doesn’t upgrade.
Please let me know if that works. Once you reached version 1.0, the update mechanism should work without renaming files. So then, you repeat step 3 to reach version 1.6. (No need to install versions 1.1 to 1.5)
In case that does not work for you, please let me know if you used SSH and the command line before, just to give me a picture of your tech-skills.
Best regards
Jakob
Sadly, this also didn’t work.
The same problem. As soon as I remove the USB cable the MOD display shows: ‘eject not detect’.
Even though I ejected the DUO storage device safely.
