Thanks for reporting
That’s indeed why these plugins are still in beta - they were not tested enough to go into the production plugins.
Just to help troubleshooting: this happens when you try to load the plugins and they don’t load at all, right? So you can even use them in your chain. Am I correct?
@dreamer, I’ve pushed an update for the TAL-Reverb-II. Please have a look, the new build is version 0.0-7. Not sure yet what the issue is with the MDA Tracker.
Please do note, that that not all the plugins in the beta store are actively maintained, tested or supported. There are many plugins in the beta section that work just fine, but there are also quite a few that have issues, ranging from small bugs to non-functional plugins.
@BramGiesen hmm, I did see the updates and was able to update both of the TAL-Reverb plugins. Both I’m able to load now. Good work!
Maybe we should have an alpha section for such plugins first. And then beta when they are actively being tested and in the process of integrating with the stable list.
I looked for Ta-Reverb-II in the pedalboard library and found this
After opening it via 192,168.51.1 in Opera it downloaded a new version of Tal-Reverb-II amongst other plugins.
Then I changed to another pedalboard and tried it again, this time with safari, it downloaded new plugin versions again.
Now it shows 0.0-7 everywhere.
I’m still on MacOS 10.14.4, by the way.
