Description
When dwarf is connected via WiFi, http://integrate.moddevices.com/ cannot connect to it
How to reproduce
- Connect the device to WiFi as explained here
- Check the UI at http://moddwarf.local - OK
- In the same browser, open https://pedalboards.moddevices.com/
- Chose pedalboard and select “Try Now”
Install Pedalboard - MOD Devices opens with the message:
“Installation failed! Please make sure your MOD device is connected so you can access the UI from this same browser. Also you must be running the latest release.”
Expected/suggested solution
A little debugging shows, it was trying to talk to 192.168.50.1 and ..51.1 but not to moddwarf.local maybe just adding this address in webapp would solve it.
Additional information
- release:1.11.6.2909
- Operating system: Windows 10
- Browser: Chome
- wifi adapter: ASUS USB-AC51
