Can Looperlative autoquantize/sync to the BeatBuddy?
I’m trying to follow my Beatbuddy when making loops. As for now I’m only using the LP3 One plugin for testing, but would concider it’s bigger brother if this is working.
So far my loops drifts off after a while, and I’m beginning to wonder what to do.
Dwarf global sync is set to Midi and it receives midi on the send channel from the BeatBuddy. I havent found a way to view the actual BPM on the Dwarf, but maybe there is a plugin that would display that?
Anyway, I’ve used the plugin with:
  • Host sync without any virtual Midi cable in the Mod GUI, and …
  • Internal Midi Sync with the virtual Midi cable inserted in the plugin.
    Maybe there’s no function to correct for the microseconds between the perfect length and my press?
    Any help appreciated.
