Hi, everybody!
This is my first post here and I would like to ask if anyone knows if can I control a Two Notes Revolt with my Mod Dwarf´s midi in / out ? What I would like to do is to have the Revolt´s channels saved on my Dwarf´s snapshots.
Thank you very much!
Dmnt
Can you be a bit more explicit on what functionality you are trying to control?
I don’t know what a “Two Notes Revolt” is or what “have the Revolt’s channels saved” means.
In what way are “channels saved”?
Two Notes Revolt is an tube preamp with 3 channels that can bew controled by midi, and I wanted it to change the channels / presets together with my change of snapshots on my Dwarf. I know that both of them have midi connections, actually Im using my Dwarf´s midi out to connect an external midi controller, so I was wondering if can I control the Revolt with the Dwarf midi connection, on the Revolt´s manual theres an explanation about how to set it, but I dont understand how can I program the Dwarf to control an external unit using midi.
Sorry for the confusion, Im new at the forum and I still learning how to use the Dwarf, its a fantastic machine, but I feel a bit lost sometimes.
Use a the infamous mindi - MOD Audio to send to correct midi message to the Dwarf’s Output.
Then save the state of the mindi with each snapshot.
