A stereo delay with resonant filters and fractally modulated panning.
The delay times are set through the bpm control and the divider adjustment. Triplet and sixteenth settings create a dotted rhythm. With every beat, the filter resonance frequencies are retuned to random steps on an equal-tempered chromatic scale, to the reference set through the tune control.
source: http://quitte.de/dsp/caps.html#Scape
Sounds pretty cool. Will there be TAP-Tempo in the future? Is it possible to set BPM via MIDI CC or Sysex (I have a small box with an Arduino that meassures the time between taps on a foot switch and sends them via MIDI)?
I’ve asked the same thing…
I play to an external drum machine/groove machine (Novation Circuit) and want my delays to sync to it. They told me they are working on doing a global BPM and hopefully sync to external machine. I like using a dual delay and have 1/4 note and a dotted 1/8th note delay…
I think, in the mean time, plugin developer should be able to make a delay that has a MIDI input for detecting BPM…
I’d really love to add a MIDI in to some existing delay and I already flew over http://lv2plug.in/book/ rather quickly. I’m highly motivated to use it as a little learning project. Unfortunately, I don’t have the time to do that at the moment. But the possibility alone to do such stunts is what’s really cool about MOD Devices.
I would like to learn programming as well… I’ve had ideas and want to implement them… Luckily the MOD team and plugin developers have been amazing at implementing the ideas I have.
