C* Click - Metronome - MOD Devices
MOD Team
A sample-accurate metronome. Two simplistic modal synthesis models are available for the click: box is a small wooden box struck with a soft wooden mallet, stick a scratchy stick hit. In addition, there's also a very synthetic beep, and finally dirac, a very nasty single-sample pulse of 0 dB amplitude and little immediate musical use. All click sounds are synthesised once when the plugin is loaded and then played back from memory. source: http://quitte.de/dsp/caps.html#Click
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL21vZGRldmljZXMuY29tL3BsdWdpbnMvY2Fwcy9DbGljaw==
