Testing on the new USB MIDI mode would be very appreciated.
(And in turn, you get the feature working well too)
There are 3 modes:
network (default)
net+midi
net+midi (windows)
The last one is required if using Windows.
Note that (a somewhat recent build of) Windows 10 is required if you want this working on Windows, because it relies on composite USB device support.
After you change the mode, click down with the right-most knob once to activate the dialog asking for reboot (which is needed for this feature)
I’ve been trying the midi, both on arch linux & debian 10 & OpenWrt with the “net+midi” and “net+midi (windows)”, and on Windows with “net+midi (windows)”. It is working great without issue.
My first question is what is the usefulness of “net+midi” over “net+midi (windows)”, considering “net+midi” works on fewer devices than the windows variant (or am I missing something)?
And one small comment is the description could be improved in mod-ui from the non-descriptive “USB Gadget MIDI 1”:
To something like “Mod USB MIDI”, or “Mod USB port A MIDI” (because that port is labeled “A” on the back of the mod), or “Mod USB Guest MIDI” to distinguish from the USB host port, or “Mod USB Computer Port”. I don’t know.
macOS does not have support for the RNDIS-style driver used in windows mode, that is basically it.
Linux works with both though, so for openwrt it does not really make a difference.
Getting a proper name for this in the webgui is difficult yes haha.
I left it as-is from the system, because I could not think of a really good one either.
There are more OSes out there than unix.
HaikuOS is POSIX but not UNIX, for example.
You should really use the net+midi all the time except if using Windows.
Windows is the odd one here, everyone else knows how to handle a CDC network device.
It is still early to tell, but when we activate audio we might end up with just 2 options. default and +midi+audio, as we are investigating Windows drivers.
class-compliant usb audio and windows is an odd mix…
