Hi everybody.
I have a big issue with my dwarf.
Regardless of the pedalboard I load, even with the most simple pedalboard I can’t save anymore. I only have this message: Bug! Couldn’t save pedalboard.
I can’t even change the statup pedalboard, when I load a other [edalboard and restart the dwarf, it always load the same pedalbaord.
Help, I can’t modify anything, it’s like having a fixed pedalboard.
My Dwarf have the last update.
Ok guys. I just find the problem. I had a 4Gb audio recording that was too big to save anything more on the dwarf. I think I have recorded by mistake this long audio.
All is fine now.
It’s cool when people actually write the solution, instead of notorious “never mind, problem solved” with no further explanation)
Hello
Hello
Check below steps to resolve the issue:
Restart Your Dwarf: Power it off completely; then turn it back on.
Factory Reset: This can fix persistent problems; but remember it will erase all settings.
Reinstall Firmware: Download and reinstall the latest firmware to fix any installation issues.
Test New Pedalboards: Create a new; simple pedalboard and see if it saves.
Hope this helps! ![]()
Thanks. I think you didn’t read my answer to my issue. The internal memory was full, that’s what caused the issue.
