How to set the brightness of the footswitch??
thankss
If you are referring to brightness of LEDs and display of the MOD Dwarf, you should read the wiki at Dwarf Device Settings - MOD Wiki
I guess you are referring to the foot switch extension pedal. I have the same problem with mine and I think that it’s not possible to adjust the brightness for it…
i have mod duo… i can’t find that setting in mine…
In the same wiki you will find the info about duo
