I captured my bass pedal board, consisting of a Boss ODB-3 and a Digitech Bad Monkey. The latter is switched off, as I only use it because of its Cabinet Simulation output.
Boss ODB-3 Bass Overdrive plus simple cab sim.json (172.0 KB)
This is my first capture and it’s not a 100% match, but after adding a bit of EQ, it close enough to the real thing.
It also works nicely with the MOD bass cabinets plugin.
Since the main point of a cab sim (cutting those nasty high frequencies) wasn’t really captured, I’ll try again without the Bad Monkey, hoping to get a better match for the OD alone. Maybe next weekend.
