Hey ![]()
I am trying to bootstrap the mod-plugin-builder following in the instructions in the read me.
I am using Raspberry Pi4 and I’m targeting the Dwarf
.bootstrap.sh moddwarf fails after about 90mins. Here is the end of the output. Any ideas?
[INFO ] Installing zlib for host: done in 9.84s (at 92:37)
[INFO ] =================================================================
[INFO ] Installing GMP for host
[EXTRA] Configuring GMP
[EXTRA] Building GMP
[ERROR] tmp-divrem_1.s:129: Error: selected processor does not support `mls r1,r4,r8,r11' in ARM mode
[ERROR] tmp-divrem_1.s:145: Error: selected processor does not support `mls r1,r4,r8,r11' in ARM mode
[ERROR] tmp-divrem_1.s:158: Error: selected processor does not support `mls r1,r4,r8,r11' in ARM mode
[ERROR] tmp-divrem_1.s:175: Error: selected processor does not support `mls r1,r4,r3,r8' in ARM mode
[ERROR] tmp-divrem_1.s:209: Error: selected processor does not support `mls r11,r4,r12,r3' in ARM mode
[ERROR] make[3]: *** [Makefile:768: divrem_1.lo] Error 1
[ERROR] make[3]: *** Waiting for unfinished jobs....
[ERROR] make[2]: *** [Makefile:956: all-recursive] Error 1
[ERROR] make[1]: *** [Makefile:775: all] Error 2
[ERROR]
[ERROR] >>
[ERROR] >> Build failed in step 'Installing GMP for host'
[ERROR] >> called in step '(top-level)'
[ERROR] >>
[ERROR] >> Error happened in: CT_DoExecLog[scripts/functions@376]
[ERROR] >> called from: do_gmp_backend[scripts/build/companion_libs/100-gmp.sh@108]
[ERROR] >> called from: do_gmp_for_host[scripts/build/companion_libs/100-gmp.sh@58]
[ERROR] >> called from: do_companion_libs_for_host[scripts/build/companion_libs.sh@36]
[ERROR] >> called from: main[scripts/crosstool-NG.sh@696]
[ERROR] >>
[ERROR] >> For more info on this error, look at the file: 'build.log'
[ERROR] >> There is a list of known issues, some with workarounds, in:
[ERROR] >> 'docs/manual/B_Known_issues.md'
[ERROR] >>
[ERROR] >> NOTE: Your configuration includes features marked EXPERIMENTAL.
[ERROR] >> Before submitting a bug report, try to reproduce it without enabling
[ERROR] >> any experimental features. Otherwise, you'll need to debug it
[ERROR] >> and present an explanation why it is a bug in crosstool-NG - or
[ERROR] >> preferably, a fix.
[ERROR] >>
[ERROR] >> If you feel this is a bug in crosstool-NG, report it at:
[ERROR] >> https://github.com/crosstool-ng/crosstool-ng/issues/
[ERROR] >>
[ERROR] >> Make sure your report includes all the information pertinent to this issue.
[ERROR] >> Read the bug reporting guidelines here:
[ERROR] >> http://crosstool-ng.github.io/support/
[ERROR]
[ERROR] (elapsed: 94:33.19)
[94:36] / gmake: *** [ct-ng:261: build] Error 2
I suspect we might need to pass some flags to crosstool-ng, but I’m not sure where I can.
Thanks in advance!
Edit: Here’s the output for .bootstrap.sh raspberrypi4
Installing ncurses for build: done in 126.66s (at 109:10)
[EXTRA] Configuring zlib
[EXTRA] Building zlib
[EXTRA] Installing zlib
[INFO ] Installing zlib for host: done in 5.78s (at 109:16)
[ERROR] /
[ERROR] >>
[ERROR] >>
[ERROR] >>
[ERROR] >>
[ERROR] >>
[ERROR] >>
[ERROR] /
[ERROR] (elapsed: 111:20.39)
[111:23] / gmake: *** [ct-ng:261: build] Error 2
