Bollie Delay - MOD Devices
Bollie Delay
This stereo tempo delay features high pass and low pass filters as well as host tempo. When using it with the MOD Duo on software version >1.2.0, then please assign a footswitch to Host/MOD-Tempo. Otherwise you can assign the tap button to a foot switch. Always make sure to set the correct tempo mode. Enjoy! :-) And feedback is always welcome.
Plugin screenshot
This is a companion discussion topic for the original entry at https://pedalboards.mod.audio/plugins/aHR0cHM6Ly9jYTkuZXUvbHYyL2JvbGxpZWRlbGF5
Hi, I’m reaching out to see if you would consider updating the plugin so the Global Tempo value would update the Current Tempo value when the plugin is set to MOD/Host Tempo Mode. Currently it does not update with this value. Thank you!
Sorry to necro this really old post, but why does the tap tempo option on this delay do nothing? If you set the mode to “Tap” and then click the tap button, nothing changes. Is this a bug or intentional?
Heey Micahvdm, I have tested this today and the tap function does work. However, the Current Tempo indicator does not seem to update for either the MOD/host, User Tempo, or Tap Tempo so this is actually a bug. I will make a ticket for this so we can look into it.
Thanks for bringing this to our attention!
That is fixed now in build 2.6-7, thanks for the report!
Is there no way to switch between BPM and milliseconds?
Bollie is the only stock delay with tap tempo, which is crucial, but the BPM is really throwing me off. BPM only makes sense if I’m locked to a tempo, like in a DAW session. With floor delay units for jamming the only thing that makes sense to me is ms.
When I tap a delay time with the hardware button, the display shows “TRIGGER”, when it would be far more useful to show the delay time in MS.
Other delay plugins are capable of syncing to a tapped tempo. You can control the global bpm with a footswitch. And lots of plugins can sync to the global bpm.
See the docs here:
https://wiki.mod.audio/wiki/Tutorial:_Using_Time_Based_Parameters
