Bluetooth Midi
Now I have set up my Dwarf Rig for our DUO. Thanks for help!
The starting point is the iPad with the setlist programme “Songbook+” https://www.songbookplus.com/
All songs with lyrics/chords and the corresponding backing tracks (mp3) are saved. (I created this for the DUO)
Now I have entered the necessary “MIDI” commands for some songs in order to have a test environment. ( already tested now)
I had to buy a “Lighning to USB3 Adapter” for my iPad. I got it on “Willhaben.at” - it’s similar to eBay.
The MIDI commands are sent to the WIDI Bud via Bluetooth as described above without WebGUI. I now want to create 3 GRigs at the Moment.
The audio signal from the iPad goes via the Lightning adapter (because of the iPad battery capacity) to the USB-B port of an external audio interface.
The audio interface or possibly the PA mixer now gets 2 mono signals from the DWARF (guitar + vocal) and 1 stereo (USB-B) for backing.
Of course, the whole set does not fit into the gig back of the guitar. But a small pedalboard is enough to pre-wire everything.
(Did I ever mention that I’m creatively lazy and prefer to bring the setup to the GIG already programmed and wired. :wink: )
For me, setting up and especially removing the set after a GIG is terrible. :unamused:
Hi folks,
I’m a new mod dwarf user and trying to setup widi jack.
The jack is connected as type a and appears to be functioning ok. iPad, midimittr and touch osc all recognise it however I can’t see it registered by dwarf and getting nothing through the serial hardware midi connections.
Have successfully hooked up a keyboard via usb and triggered the generators no problem so it seems like my issue is the serial ports and/or widi jack.
Any suggestions folks? My aim will be to use the widi jack with a korg air keyboard, for now I’m just wanting to test the system with the iPad…
Cheers! X
Do you have the little switch on the WIDI Jack flipped to use a type A TRS connection?
Are you sure that you are plugin the out from the WIDI Jack to the In from the Dwarf?
Do you have the WIDI jack power (with a USB cable connected to the USB C port of the WIDI Jack)?
I know that this may sound like silly questions and that some of them you sort of answered, but I’m double checking.
I personally use a WIDI Jack with the Dwarf (even yesterday) and have no problems. Just normally some confusion between ins and outs or the WIDI pairing to something else.
Thanks Jon,
I think I’ve checked everything:
  • Definitely set to type A. If I switch to type B then the blue light is out and nothing works.
  • The in and out connections are correct between the dwarf and Widi jack, I have tried reversing them to see if this makes a difference. It doesn’t although interestingly the Widi jack still powers and connects to the iPad successfully when the connections are reversed - not sure if this is significant or not?
  • The Widi jack seems to power just fine from the midi cables but I have also tried it with the USB power connected as well - does not appear to have any bearing at all
Could I ask you - when you are using your Widi jack does it show up as ‘Widi jack’ in the Dwarf GUI midi ports setting? I have succesfully linked and Ampero Control pedal and a Komplete Kontrol S61 Mk2 keyboard - both of these show up straight away and are named (connected via USB midi)
Do I somehow need to enable the midi hardware ports separately to the USB midi? Can’t find anything in settings to suggest this but it is almost like my Dwarf has the hardware ports deactivated somehow… It’s founders edition if that has any bearing…
Thanks for your help matey!!
x
You’re welcome
pairing should indeed do regardless of right or wrong connections.
But wait…are you pairing it with the iPad? Are you trying to send MIDI messages from the iPad to the Dwarf (via WIDI)?
I believe that is true if you use the MIDI in on the WIDI. This I’m not sure because currently I’m not using that.
No because you connect it on the serial MIDI ports and not via USB. Therefore it shows up with the name of the serial driver.
Over all your message I was getting this confusion and here even more. Are you trying to use the USB to connect and send MIDI to the Dwarf? The WIDI USB is just for power.
Hi - re the USB power, no, not using that to try and send data, I just tried it to see if powering the Widi jack this way helped at all. Scraping the bottom of the barrel!
Potential key point though - yes, I am trying to send midi data from my iPad. I have midimttr hooked up with Touch OSC and I’m trying to send pitch info to drive some of the sound generators on dwaft. I have a small virtual keyboard set up on Touch OSC.
As I play the keys on the iPad I can see the midi light flashing on the Widi Jack so I believe all of that is working ok, but nothing seems to be getting through to the Dwarf…
Re the naming conventions that makes perfect sense. So I should expect to use the port labled ‘hardware serial MIDI in’ - that’s the one I’ve been trying to use without success.
Does Dwarf perhaps not like midi from the iPad…?
I don’t see any reason for that. In any case, do you have anything else to try?
Check also this thread Looking for beginner tips for synth pedalboard
Thanks Jon,
Unfortunately nothing else I can try with the serial ports and widi jack
Korg air keys on order, I guess I may have to wait for that
Anything else you can think of…?
Not really.
I still feel that the problem is somewhere on the WIDI setup (or what is receiving).
Does the LED blink when you send a note from the iPad?
Otherwise, indeed it will be better to wait.
I just bought a Tp-link UB400 and connect to my tablet. What USB HUB can I use to expand the USB A on mod dwarf? Do we have a list for that? I want to use multiple midi controllers and the wireless dongle on USB A
All the ones I’ve tested have worked.
(I think any hub should work)
was it blue? usb 3.0 or 3.1? or older ones like 2.0?
all of those kinds
thank you thank you! :pray:
