@falkTX
Can you also add the list of BT 5.0 included in the release?
I’ve an Asus and I’d like to test
if you can tell me the firmware filenames needed, I can make sure to include those.
or possibly just confirm the chipset (or is it not that simple?)
It is not that easy, normally the chipset specs are well hidden or not directly disclosed. The TP Link UB500 has a Realtek RTL8761B chipset, also shared by many other inexpensive
BT USB dongles.
Well… I don’t know how to do it if you don’t descrive me!!
Actually it’s mounted on al PC… Can it help?
@falkTX … If it can help, I have downloaded from Asus site the Linux BT driver (to be compiled) for the USB-BT500 usb adapter.
I don’t have Linux on my PC but this is the short on release note:
Release History:
20200806:
update the config file for rtl8821cu to fix the bring-up issue on Linux Kernel 4.19+
add the support for RTL8723F
20200610:
update the FW files for rtl8821c and rtl8761b
Software Package Feature:
Bluez
Other software based on HCI, L2CAP, RFCOMM, SCO and Management sock
Hardware Supported:
All Realtek Bluetooth Chip.
Platform Supported:
Linux kernel V2.6.32-5.7.1
CPU supported:
ARM/MIPS/X86
==== BT USB CHIPS ====
rtl8761bu_fw BTCOEX_20190327-0202 FW_VER= 0x999646b
==== BT UART CHIPS ====
rtl8761b_fw BTCOEX_20190327-0202 FW_VER= 0xd99646b
The “rtl” (realtek) ones are all enabled so in theory the new/next 1.13 build should work for you.
And in any case we can easily add more later on as we find more missing firmware.
Yes. In Device Manager on Windows, you can access the Properties, and on the Details tab you can see the Hardware IDs , which will identify the chipset used by your Asus device
meanwhile i purchased a Bluetooth 4.0 Adapter. This Adapter works. I can connect via Android and via Windows. But i cannot reach 192.168.50.1 … nowhere
always get an “Network unreachable” error …
Now my Android sais “turn on teathering on MOD Dwarf” …
Hi @ChrissRea
Did you turn off mobile-data and/or wifi ?
(if you stay connected to internet with wifi or LTE Android keep searching the IP 192.168.50.1 on the web)
meanwhile i soplved the Problems via console commands for manage Bluetooth.
Hello @ChrissRea,
how did You do that?
It would be nice to show what you have done, it might be helpful for other community members, too.
Hi I am using an usb 5.0 bt dongle, accessed ssh and I’ve this info
hci0: Type: BR/EDR Bus: USB
BD Address: 00:1A:7D:DA:71:13 ACL MTU: 679:8 SCO MTU: 48:16
UP RUNNING PSCAN ISCAN
RX bytes:1527 acl:0 sco:0 events:59 errors:0
TX bytes:1756 acl:0 sco:0 commands:59 errors:0
Features: 0xbf 0x3e 0x4d 0xfa 0xdb 0x3d 0x7b 0xc7
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH SNIFF
Link mode: SLAVE ACCEPT
Class: 0x020000
Service Classes: Networking
Device Class: Miscellaneous,
HCI Version: (0x9) Revision: 0x810
LMP Version: (0x9) Subversion: 0x2312
Manufacturer: Cambridge Silicon Radio (10)
I don’t know why, but I am not able to connect
