Hey All,
Check out this interesting accessory! I can’t seem to find pricing or availability though:
Hey All,
Hello,
Did you try it ? It’s available for 138€
I was hoping to (try to) add en expression pedal jack to the modswitch, but this solution seems quite perfect !
I haven’t tried it! Since then, I have been playing with a Roland PK-5A…
I have one of these and using with the Dwarf. It’s great. Gives you 2 expression inputs too
Yes, I’ve bought it too, it works pretty well out of the box !
And I sold it because you can just send 1 message per footswitch, so it’s a bit time consuming and (Dwarf’s CPU consuming too) to make this one message do multiple things.
Yes only one message at a time, but the dwarf can take in the single message and send multiple out at the same time which works great for my use case.
