Chris_P
1
Description
I use a beatstep pro on midi Chanel 3, 4 and 10
It works 's fine when the sequencer is running
How to reproduce
When I stop the sequence on the beatstep the Mod duox is buzzing and the CPU ( around 13 %) flashes red , I had to switch it off
3.
Expected/suggested solution
May be it’s the midi configuration that’s not well done
Additional information
V11.11.6
- Operating system:mac
- System version: 10.15.7
Chris_P
2
I will go step by step :
If I use only one chanel 10 it works fine, the mod stop and go .
I 'll continue to see if I can reproduce the problem that I had
Chris_P
3
Finaly I found that I have the problem when I use the Nekobi generator
falkTX
4
oh, that seems familiar.
Supposedly fixed with Fix SysEx events causing an infinite loop by PolyCement · Pull Request #16 · DISTRHO/Nekobi · GitHub
I am going to make a release of DPF-Plugins soon, which includes this.
Then include it in MOD store updates once it comes online again.
