Beat/Rhythm detector/tracker
My use case:
  1. I record a freeform loop (or I just play)
  2. then I launch a drum machine, or a delay, or anything using midi sync
  3. The drum machine is synchronized with my loop/playing
This feature exists in some loopers like the Aeros and the RC500.
It seems various plugins in various formats already do that :
http://teragonaudio.com/BeatCounter.html
http://www.pogo.org.uk/~mark/bpm-tools/
http://doc.sccode.org/Classes/AutoTrack.html
http://doc.sccode.org/Classes/BeatTrack.html
Could anybody port this to the Mod environment ?
Thank you very much !
The LP3 plugin provides MIDI clock out based on your loop length.
Thank you. I suppose it means that if my loop is one measure in 4/4, then I will have to multiply the LP3 clock by 4 to have my tempo, but that a good start ! :slight_smile: I will take a look.
Yes, that is the assumption that the LP3 makes. So, keep that in mind when you build your drum track.
