Kevin
January 30, 2025, 4:07pm
1
Is there a way to press B and C simultaneously without going into the preset/pedalboard menu?
I really want to assign each to a control parameter and activate them at the same time
I never use the tuner so would far prefer the preset menu activated by A and B.
Extra frustrating is that my Fbv controller won’t permit this either, if one button is pressed it has to be released b4 pressing another
Thanks in advance
jon
February 6, 2025, 3:07pm
2
Unfortunately, that’s not possible at this time.
The function of combined buttons is not open to being edited. Sorry
Kevin
February 24, 2025, 3:55pm
3
Have you any thoughts on other devices that could be used with the dwarf that might facilitate this?
I know the fbv won’t nor the morningstar mc6…
Abotte
February 24, 2025, 6:01pm
4
Not sure if I understood your need, but can’t you use CV to if you want to map a single button to 2 or more different parameters? I use CV all the time to enable multiple effects at once.
Kevin
February 24, 2025, 6:08pm
5
Not quite, I want x2 buttons for x2 effects, which you would think sounds straight forward enough, but the dwarf has a menu assigned to both double button presses, whereas the morning star and fbv don’t register a 2nd button if another is already pressed.
Zavorra
February 24, 2025, 7:07pm
6
PedalinoMini Is a DIY open source project, really customizable
I have built one and really love it.
According to specs it is able to handle simultaneous presses (I haven’t tried)
even If you are not into diy, I think you can ask the author for an already built unit according to your specs.
More info here https://github.com/alf45tar/PedalinoMini
Kevin
February 27, 2025, 4:55pm
7
Looks cool! I haven’t come across that one before!
