AX84 P1 DIY Amp - Amp Only - ESR 0.02
Single 12AX7 and a single EL34 amp. Marshall sounding JTM ish. Set up as a pedal platform so just a little bit of break up. DI through Two Notes Captor into Logic. Guitar used, Fender Mustang with humbuckers so pushing the front a bit more than a single coil.
Clean AX84 P1.json (81.4 KB)
