Avoid plugin changes through snapshots
Hi!
I’ve done a simple workaround to exclude the parameters of a plugin to change along the snapshots of a pedalboard. You can edit the snapshots json file of the pedalboard deleting the code, referencing the plugin that you want, with a software like WinSCP.
You can see how I do it in the video with a little application that I’ve made in HTML. I share the application too. Use it at your own risk and remember to do a copy of your pedalboard before using it.
Mod Dwarf edit snapshots
Snapshot editor
Yes, its always been a hassle to change plugin parameters across snapshots. And this is a solution, allthough it takes som effort. Thank you for the video and the editor!
Hi! And thanks but the best way to do it now is with the Starless unofficial Dwarf image - ALABS. It’s cool
