First topic of my own on here to apologies in advance for any naivete in the question.
I really like the amsynth plugin (amsynth - MOD Devices) for a drone background, but was wondering if there was any way to automate the cutoff and/or resonance - say between 30% and 70% over two bars (back and forth) - as if you were a robot who could control an expression pedal perfectly and identically
I think the key here will be using a LFO (CV) to change the parameter.
I’m sure I’ve seen a video of someone doing that on a MOD device recently… if I can find it I’ll post back here (if someone else doesn’t find it first).
If you have a dwarf this will soon be possible in v1.11 with the midi loopback feature.
the step sequencer can have some notes, then a midi note to CC converter on top and going into the loopback port, which is then possible to assign as midi learn.
this will basically allow a step sequencer to become a control/parameter-change sequencer
we are sorting out the last details for v1.11, but there is quite a fair bit still to do, we will have v1.10.2 before that one.
