I was wondering if it would be possible to set the Duo so that it goes into hardware bypass between pedalboards.
Most people probably won’t probably require this but I think it may be a nice feature just so that there is some kind of sound going through. It may be good in the event that something doesn’t work and the next pedalboard doesn’t load… in which case the duo is already in hardware bypass and hopefully the gig can go on…
Another reason for having it go this way is that I may want a different pedalboard at different parts of a song which are NOT right after each other. For example I may have an intro that uses some freaky plugins then want another pedalboard later in the song. In this scenario, at the end of the intro I could hit the button to go to the next pedalboard in the bank but it will go into hardware bypass and when the section comes up I can engage the Duo.
It would be nice to have that as an option.
Thanks for listening.
