Description
I’ve built a control chain device (code here)
I have the issue that when I turn on the mod, the footswitch does not get the assignments correctly. If I reload the pedalboard a few times (via left knob> banks>etc) then the assignments will come through.
Furthermore, an offical mod devices footswitch is not always recognised when connected after my diy device. By which I mean I cannot assign to it from the gui. Sometime disconnecting and plugging it in again works.
How to reproduce
- Load an arduino shield with the code provided
- make some cc assignments and save a pedal board
- reboot the mod
Expected/suggested solution
I would expect the assignments to work on reboot.
Additional information
Open the controller menu (hold left knob down), navigate to Info > Versions and write down here the versions.
- release: 1.6.1
- controller: 0.2.2
Note I fully expect this to be an issue with my arduino code, rather than with the mod duo.
