Assignment/Setting Question
Hello,
questions asked in the video YT - Meet the MOD Duo X | A Magic Rectangle :
  • Is it possible to set the range to negative (-127 to 127)?
  • Is it possible to assign several parameters with one controller?
  • More pages?
I would like to know if this is technically possible, musically interesting?
Cheers :sunglasses:
@ModDou_Developer Would that be technically possible to implement?
What do the other ModDuo users think?
I would find these functions useful.
You can always change the ranges, assuming the plugin supports it
Yes, made possible in v1.9 with the CV output addressing.
See https://wiki.moddevices.com/wiki/CV_Tutorial#Setting_up_Macro-Controls_using_CV
This is coming in a later update, likely v1.10, since it is ā€œjustā€ adding a few more colors.
Great! That sounds very good. Thanks a lot.
Does it also work with the Devices/MIDI controllers?
Yes of course. You just map the ā€œmetaā€-like control-to-cv parameter to a MIDI CC.
Great :sunglasses: and thanks for support.
Is it possible to browse the pages backwards, both directions?
no, but there are only a few ones anyway (they cycle back at the end)
OK. Where browsing backwards can be very useful in some cases. IMHO
Is this also possible (or will be in a not too long time) possible with the Duo?
@khz We hear you,
When we enable the use of (up to) 6 pages instead of 3, we will also change the device setting called ā€œPAGES MODEā€. Currently it switches between ā€œ1 BUTTONā€ and ā€œ3 BUTTONSā€. The setting will change to switch between ā€œ1 BUTTONā€ and ā€œ2 BUTTONSā€, where the two buttons will be used for prev/next page, and the third push button will still be available for instant snapshots.
//Jesse
@Tarrasque73,
With firmware version 1.9 and over the Duo is also capable of doing the same thing.
  • Drag in the MOD Control to CV plugin
  • Click on ā€œManage CV Portsā€ in the top bar of the web interface
  • Enable output of MOD Control to CV by clicking the checkbox and optionally give it a nicer name (I’d suggest something like ā€œMACRO Xā€)
  • Now MACRO X is available as an addressing source under ā€œCVā€, you can assign it to as many plugin parameters as you desire
  • Map the ā€œControlā€ parameter of the MOD Control to CV plugin to a device actuator and voila, your macro is all set up
//Jesse
@jesse
How about e. g:
To turn the pages forward press the ā€œ2 BUTTONā€,
to turn the pages backward press the ā€œ2 BUTTONā€ and simultaneously the ā€œ1 BUTTONā€.
The setting in ā€œDevice Settingsā€ - ā€œPages Modeā€ > ā€œ3 buttonsā€ is very good.
