I am trying to switch two stereo switch-blocks at the same time from a single pedal control. The idea is I have a looper and I want to be able to switch it to record/playback from the start of the audio chain or the end of the audio chain based on a pedal switch state.
I.e. Record the guitar on input and play back through the audio chain (and so I can fiddle with controls without playing to try different sounds) OR the normal use case and simply record the output audio chain and play back to output for normal looping backing tracks.
Having this feature would be really useful for this. However another way it could be possible that is more in line with what already exists is to use a CV port somehow.
The issue is I cant assign a CV to select between the different Switchbox channels OR presets. They are only assignable to knobs, MIDI or control chain. I would love some kind of primitive to make a CV look like a knob on the device!
