Arduino: how to print something on serial monitor
Hello, I try to use arduino shield with control chain. I must say that I didn’t think to be so far to something working well.
I can’t make a simple program to have 2 buttons with leds, that would be really the minimum. Is there any example of that ?
Something really hard is that I don’t know how to show informations from code anywhere (Serial.print() doesn’t works, and since we are plugged to the mod duo…).
I’ve got really frequent control chain disconnect when I try to assign a button.
Hello @houston4444
The easiest way to start is using one of the examples. You’ll find them at File > Examples > ControlChain. There is a button example in there.
Also check these blog posts for further information:
http://blog.moddevices.com/2017/05/06/tutorial-arduino-control-chain/
http://blog.moddevices.com/2017/11/20/tutorial-control-chain-distance-sensor/
http://blog.moddevices.com/2018/01/15/tutorial-liquidcrystal-and-control-chain/
You won’t be able to use the Serial to debug since it’s being used by the library.
Ok, I did already use Button.ino example, and already read the tutorial. I’ll take a look to distance sensor, it seems to be amazing.
Last night, I arrived to get two buttons and leds working using assignment->id in updateLed fonction.
I also call an updateAssignment fonction related to CC_EV_ASSIGNMENT to get led status just when Button is assigned to a plugin switch, it works.
CC_EV_UNASSIGNMENT seems to not work.
The main bug I have now, is that updateLED seems to not be call when i switch presets (if button is assigned to an effect that is ON on one preset, and OFF on another one). I also have controlchain disconnection when I switch many times these presets.
huge disappointment: It’s not possible to affect a controlchain button to global tempo, button doesn’t appears in menu, grrrrr.
