ANAGRAM effects
I saw that MOD was involved in the development of the Darkglass Anagram pedal, so I was wondering if there’s any chance they could push to get those effects released on the MOD Dwarf store.
I know it’s probably unlikely, but I’d definitely buy them if it happened, especially the Entropia distortion.
The team is dead-silence since a few weeks (the team is regularly silence) but I had the impression that the fusion between the anagram-store and the mod store is on the way…
But it seams a hard update since it should first change the way the mod-store is made :
  • now the plugins bought are linked with the device (Dwarf or DuoX…)
  • then they would be linked with the user (so you could have them on multiple devices : desktop, dwarf, anagram…)
Yeah I’d love some more bass oriented effects on MOD!
Is any plug in or mix of plugins in the MOD shop that could get a similar result like the Entropia? i.e a mix of a compressor , eq and distortion?
I just checked the little announcement video of Entropia, but I believe that in the MOD platform, you can, for example, layer an input with multiple EQs or filters and after each, add a distortion effect. After that, you can use something like the mixer plugin or some gain plugins to adjust the levels and have both a not super high gain level and as well as control over the level of each band.
I’m pretty sure oversimplifying, but that could be a starting point :slight_smile:
