Aurelien Leblond
The AMS VCA Lin module is a linear Voltage Controlled Amplifier used for volume modulation. It allows you to, for instance, modulate the output of the AMS VCO3 using the control voltage signal of the AMS Env. Features: Ported from the AlsaModularSynth, a free and open-source project.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2dpdGh1Yi5jb20vYmxhYmxhY2svYW1zLWx2Mi92Y2FsaW4=
