Adjust in GUI and MOD
I noticed that when I assign a parameter to a switch, knob or midi, I can’t make adjustments in the GUI.
Is there a reason for this?
I like keeping my duo on the floor and play and make adjustments through the GUI. I don’t want to bend over and make an adjustment.
Maybe there is a reason for this but I think it would be a good update.
Thanks for listening.
@Skydiver
I agree with you. It is a bummer the need to reach out to the MOD to modify parameters assigned to switches.
Maybe the GUI could have a toggle to lock/unlock the parameter which is assigned to a switch.
@Skydiver unfortunately we had to enforce this limitation due to technical issues. This is one of those problems that is a lot harder than it looks.
The good news is that this is all a software problem. So given the proper time and upvotes on this issue, it will eventually get fixed.
Where can I cast my vote? :smile:
Yes, it would be so handy to be able to do this!! It can really kill the joy to have to interrupt my workflow to reach down to the floor and adjust a knob.
@gianfranco, @acunha: Admittedly it’s only seven users who like the question, but still. Where can we vote for this (and other) issues?
