Could you add a progress bar when saving a pedalboard so that you can see when it is completely saved?
Since the audio process has priority, it may take a while until the pedalboard is saved. I am currently oriented to the CPU/RAM utilization. If this falls back to the previous value I assume that it is saved. With some pedalboards where I have previously loaded a new pedalboard but no preview images were already saved.
I believe that you have that already on the top of the screen, no?
Yes, but this ran through quite quickly, but the CPU/RAM is still under increased load afterwards. I thought that he is then not quite ready.
the increased cpu load after a save is for the thumbnail generation.
pedalboard is saved when the notification appears
Hi @falkTX . I’ve notice that and was wondering… IS It possible a feature to generate the thumbnail only upon request ?
How about progress bar on Dwarf when loading pedalboards - sometimes mine hangs without me noticing especially on big boards
I saved that on our requests list @rogeriocouto
Thanks @jon !
