This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/pedalboards/5c01c6832564d433e78f67a3?fbclid=IwAR1liuibMpoZGaUEdMHFj40FA0DJyyVJgy_ealjb9bPh5e1F-zrzU3en4oQ
