This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/pedalboards/5c01c6832564d433e78f67a3?fbclid=IwAR1ZbaX0tfiWKckgjZb87zKs6OKh8ZsGXNDbTX5eEgmKyVEVSRRQ4j2Ou0k
