This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/pedalboards/5c01c6832564d433e78f67a3?fbclid=IwAR3kFwY5GPKyVEW15QlfFnGWDrW4Qm03PtVb1ipSbHHcBSdgx7H7130AaiA
