3 channels: Clean, Rhythm & Solo (use footswitches 1 & 2), connect output 1 to flat response amp with guitar cab, connect output 2 to mixer or flat response amp with flat response cab, pickup used for setup: DiMarzio X2N DP102 on a Yamaha RGX312
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com//pedalboards/57a714c32564d4056beb1cdf
