I’m not writing to the port, or at least I don’t think so. In my instance data I have the port defined as:
const float * clear_all_port;
That gets set in the connect_port() and then in my run() method I’m simply trying to test in an if statement:
if (*self->clear_all_port > 0.0) {
That’s it, apart from a print statement trying to check the value. Which like I say is 0.0 on initisation, but after the first press goes to 1.0 and never changes from there.
Checked out sooperlooper and whilst it does not build from my environment:
cp: cannot stat '.../mod-plugin-builder/plugins-dep/../plugins/package/sooperlooper-lv2//sooperlooper.lv2/*': No such file or directory
It did mean I could look at the code and its ‘reset’ functionality was exactly what I was looking for. It’s got a different definition in TTL which works great.
Thanks for pointing out that example. Got me moving again.
