khz
2
Connect via USB/MIDI, set the master to “internal” and the slave to “USB” or “MIDI”.
https://wiki.mod.audio/wiki/Device_Settings#Sync_.26_MIDI
I use the plugin to send the “clock” as well as the “start/stop” command.
I’m not sure if this works reliably between 2 mod devices at the moment:
Should be solved soon though.
