It didn’t work
. It’s not really important, I’m only experimenting.
From what I understand the Mixer plugin is also CPU hungry. Maybe change that for some Tiny Gain plugins and then reverb into portal into RmPro. Since you are on Mod Duo X you could also experiment using more portals though it might affect latency. However I find that combining parts of pedalboards with 128 with parts that have added latency due to portal sounds great. Especially when the parts with latency are connected to reverb or delays and such! Keep experimenting! It`s amazing what these devices are capable of!
Thanks! Good idea! I’ll try that.
It depends on the use case. I’m trying to build a mixer based on the Duo X and an USB audio interface. I experimented with two different approaches: First, dedicated volume plugins (almost 40 instances) for each bus. Second, cascaded mixers (11 instances) for each bus.
In both scenarios CPU usage was pretty much the same while I even got VU-meters, pan and mute included in the mixers. The only disadvantage is that the usage of the AUX bus in the mixer plugin is muting the signal on main which complicates stuff like send effects. Working on my own fork for that.
