Starless by aLabs – Development
yes this is useful, it seams a concurrency problem between the overlay and the time3 isr.
do you had and overlay when it happened?
I’m sorry,
It’s not perfectly clear to me what is an overlay: do you mean if I had the web gui opened?
I had indeed the web gui opened, but I was using the knobs and footswitchs of the device. The web gui was in constructor mode, with no plugins window open. On the device, I was in Control mode, the default view.
no an overlay is a “dialog” on the mod device screen like the snapshot browser or a list parameter.
Thanks for the explanation; i didn’t have a dialog open then.
I think I was using the 3rd knob to control Toggle parameter of Remy’s Fade Stereo plugin.
Hi @plutek, @khz, @S_Righteous
a duo & duox binary was just released \o/: Starless – Release Announcements - #20 by AndreaDelSignore
there are some limits please read the release notes.
Wow !
I haven’t visited the forum in ages, and so much stuff has changed ! It’s crazy.
As I haven’t yet had the time to catch up with everything, forgive me if that idea is already implemented in either the stock OS or Starless, but one feature I’ve always wanted to see is the ability to drop a effect onto a cable in order to insert it in the chain, rather than having to undo the original cable to redo the connections on each side of the new plugin.
I’ve seen that it’s possible with the On-device editor, but is there anything similar for the Web UI?
