Starless by aLabs – Development
Hmmm not managing to import the image.
I go through the process but when the device reboots I have a sort of “blank” board loaded, the name is on top but under that I have “Knob 1” “Knob2” & “Foot B” “Foot C” :frowning:
Any tips ?
it seems a bug loading the pedalboard, can you check if fails with any pedalboard you have or it’s just that?
Hmmm same even on a basic pedal-board, the title changes, the sound output is what it should be (desktop UI loads) but the device’s on screen info is “blank” and no controls via knobs or Foot switches
Have you entered the edit mode?
Press the left square button than edit and select a plugin.
I can yes
Fixed, thanks for the very precise info
Sorry but I don’t understand your problem: can you describe better, what you expect to see and what you see instead?
Sorry, here’s a quick video, hope that clears things up.
I should be seeing the linked switches and knobs I chose for different plugins or have they been reset ?
I can’t manage to boot the web UI right now for some reason so can’t check if the links have been reset …
I think that you expect your configured controls there, so think there’s a bug trigger by some plugin you are using.
Can you send me the pedalboard?
This is fabulous news - thanks so much!
I’m on holiday with my MOD but no USB cable, but can’t wait to try it!
Are you considering adding the ability to assign parameters directly on the device? Feels like it’s sort of only one step on from parameter editing, and that would really be the icing on the cake!
Yes, its great!! Some of this features are highly requested by many users. I’ll try it asap!!! Thanks @AndreaDelSignore!
Yes. It seems that the device assignments aren’t recognized in some pedalboards created with the official MOD firmware. I’m trying a workaround by modifying the addressings.json, but I haven’t found a solution yet.
Good job !
Thanks :pray:t2:
Send me one of such pedalboard please, I’ll take a look before the next release(which is planned this weekend)
Done!
This is my pedalboard:
Hey would you mind explain to me how you found the link to your pedalboard as it doesn’t appear on the home page of pedal boards and I can’t find mine either that was published three days ago :thinking::pray:t2:
I’m not sure… I can go here: AX_Bruno059v6 - MOD Audio
Use the Try now link with your Dwarf connected via USB.
Thanks, I can reproduce the error, let’s see if it can be fixed quickly
I need to investigate a bit more, but it was an easy fix, the real reason is why, pratically that part was the original Dwarf code…
Thanks for the pedalboard example!
I found it !
BETA Plugins …
If you can just confirm that it doesn’t work for you either for the moment … thanks !
