Awesome work brummer! I really appreciate your work
Thanks, I’m glad you like it.
Still, it looks like those new plugs and skins don’t enter the MOD /testing area so fast, so those remain to the ones who build them by themself.
Awesome!
When can I put these pedal on a board, and play with them?
I’m sorry, I running out of time, I don’t know when I found time to continue the work on those, so that they could enter the MOD store.
Thanks, hope you will find time, they sure look nice!
I was waiting for you since you told me you had more changes.
If you can’t work on the plugins so soon, I can push the current versions to the store.
Does that sound good to you?
On the DSP side they are all fine and stable, but some of the plugs have issues within the MOD UI, like Knobs or pedal not showing, etc. I guess I’ve screwed up the css file format.
The Gu’vnor and the Hyperion been clean and stable, the others, well has UI issues.
I finally found some time and fixed a couple of those plug UI’s.
Now, all plugs included in the GxModBuildScripts repository been fixed and build / behave smooth on the MOD.
They are ready to enter testing.
For reference those are for now:
GxSuppaToneBender.lv2
GxSuperFuzz.lv2
GxSlowGear.lv2
GxHyperion.lv2
GxVoodoFuzz.lv2
GxSaturator.lv2
GxVintageFuzzMaster.lv2
GxGuvnor.lv2
GxHotBox.lv2
You can take the build scripts from there, I’ve updated the git revision number and removed all stuff I haven’t fixed jet.
Well, the HotBox wasn’t mention here before, so, it’s a tube based preamp simulation based on the well known pedal from Matchless, which, I love a lot. It brings a nice clean tone, up to slight distortion/overdrive, the tone controls been interactive, means, for example the bass control not only the low end, but as well the highs. And visa-vi, treble also control the lows. Once you are get to it, it’s cool.
It comes with it’s own bypass (ramped up and down) for smooth on/off switching.
All plugins added/updated in the (unstable) store,
except slowgear and vintagefuzzmaster (those were in stable, so need a bit more attention, will check them soon).
