With the current implementation it is accurate until 1 cent.
Each bar represents 10 cents, so the first bar is filled when the signal is between 1-10 cents out of tune, the second bar when it is 11-20 cents out of tune, etc.
//Jesse
//Jesse
@jesse
Thank you for the data. Good to know.
The visual representation gives a feeling that it may not be as accurate as it is. However, the large display is very nice and easy to see. Some tuners have a needle that moves and when itās in the middle there is another indicator that gives a nice visual to indicate you are in tune⦠This has nothing to do with the actual accuracy but a good visual can help with confidence of the user.
Iām confident now that I know the accuracy⦠
