Power supply recommendations?
UPDATE 2 :
Time for a report. Since I’ve received some power supplies or borrowed other devices to test against the noise, here’s a report about what I’ve found out to work (/!\ for my particular issue, it might not work in your specific case) :
  • Gonine 12V Alimentation 2A 24W AC 100-240V à DC 12V : https://amzn.eu/d/3Xx6CDt
    100% : Worked right away. Comes with a nice on/off switch (but I disconnect the PS either way)
  • Signcomplex LED Schaltnetzteil 12V DC 2A : https://amzn.eu/d/3QaOcL2
    100% : Worked right away. This one was already recommand here earlier. And … still effective ^^
  • Palmer RIVER iller : https://amzn.eu/d/ddN9G1A
    85~90% : Works but if I get close to the speakers, I can slightly hear the noise in the background. Pricey but compact.
  • Millenium DI-E : Millenium DI-E – Thomann France
    95-100% : Worked right away. My sound is a bit less louder than using a PS. No idea why.
  • Behringer DI400P : https://amzn.eu/d/09IUp6x
    95-100% : Worked right away. Same as the Millenium but it’s hardly noticeable too.
The DI box (Thank you again Jandalf for your advices and help) seems one of the best option to me here, since you get to keep the original PS and its intended use. It could also serves other purposes. I tend to prefer using the Gonine thingy since I get less messy cables everywhere. Both are inexpensive options (you still need a specific cable for the DI box, but it’s inexpensive too).
For once I’m glad I have trouble with throwing stuff away, on the premise that it might come in handy later :wink:
I found 3 12V DC adapters in storage with center +, of which 2 actually work noisefree, whoohoo!
Both are no name Chinese products that I wasn’t able to find online, and I have no idea what device they originally shipped with.
Just to confirm what others have said. The Signcomplex power supply https://www.amazon.it/gp/product/B073PQ7M8Z/ works perfectly for me. I will also note that when connecting directly to the mixer, using a balanced TRS → XLR cable helps.
I have an older rack mount power conditioner that I found second hand at a local music shoppe. $50. Everything else is plugged into that.
Pedals or anything that uses a barrel connector within acceptable wattage and appropriate voltage uses a PSU from Cioks.
TheGigRig also has some compelling units but, not quite as flexible.
When it comes to power, don’t skimp! It’s not exciting (unless you put yourself in the circuit…) but, it’s the most crucial part of any rig.
I plan on upgrading to an enterprise level rackmount battery backup PSU from Micro Center later on. Joke’s on any venue that tries to cut the power off when they want us to stop playing! :pouting_cat::joy_cat:
